Hi, I was just wondering if anyone cud give me a walkthrough on how to load lyrics onto my Vaio Pocket 40gb, i need to know where and how to put folers and everything to do it, cheers, david.
Hi
go there
http://www.club-vaio.sony-europe.com/clubvaio/mvnforum/viewthread?thread=14952
...and join nice talking....
yeah ive seen that thanks, but im not sure wat kinda files to use or if to create a folder as i would a music one and files in?
Lyrics works only with ATRAC3 or ATRAC3PLUS files so You should use this ones.
....I'm afraid i don't understand rest of the question ......
Hi nufcmk
I'll try to give You full guide......
from the beginning:
1. You Have to go inside the album (double klick on the name of album)
2. then left klick on track (which You want to load lyrics) and choose 'properties'
3. go to Additional info and klick on Edit... button which stand on the top of the window beside text Lyrics
\\\ New window appears ///
4. Mark Edit - Black area turns White
Now You can write whatever You like or just load lyrics from the *.txt file
Klick on Browse... button and choose file You want to load
All text from this file should appear in top area
5. Klick OK button
Remember - Square beside Edit (just under the lyrics area) have to be marked
6. Klick OK button in Track Properties window
If You want to check if You load lyrics properly - play this track and klick on album cover spining beside play/pause button
If new window with lyrics appears, this means everything goes Ok.
before You transfer track (with lyrics) to Your VAIO make sure You have those settings:
I. OPTIONS -> TRANSFER
mark "Include additional information when transfering tracks to the memory stick or network walkman"
II. OPTIONS -> TRANSFER -> TRANSFER MODE
ATRAC AUDIO DEVICE -> SET TRANSFER MODE
mark "minimum bit rate transfer mode (atrac3 plus 48kbps)"
or just make sure You're transfering Atrac files because lyrics doesn't work with MP3
P.S. I'm waiting for results ....
thanks alot mate, ive learnt how to do it now,
cheers,
david
