Hi
I've upgraded from Vista to 7 and still can't get Magicgate to work (no icons in disk drive window)
I had an error message in base system device so downloaded 3memory card drivers and now base system device has dissappeared from device manager. Under IDE ATA/ATAPI controllers Richoh memory Host controller is listed.
Can't find anything anywhere that refers to magicgate and not even sure I have installed drivers in correct place.
Under SD host adapter is SDA standard compliant SD Host Controller using a windows system driver.
Going round in circles and really appreciate some help.
