rugid22
mcafee 60 day trial
please help have managed to remove this feature without installing it is there an way of getting it back??rugid22
Thalamus.
Champion
Hi rugid22,
welcome to Club VAIO.. :slight_smile:
You could try a system restore to a point before you removed Mcaffee from your Vaio..
Use the following link for a guide should you need itSystem Restore? .. :slight_smile:
If that does not work, then most but not all of the pre-installed applications can be re-installed by doing the following, unfortunately I don't think Mcaffe is one of those available..
Click Start, then select All Programs then select Vaio Recovery Tool and finally click on Vaio Recovery utility.
Once the Vaio Recovery utility has loaded, click the Options button and select Recover Specific Applications that were pre-installed, click OK, then Yes and Yes again.
Select the application you wish to install from the list and then click Install
If I'm right and Mcaffe is not available, by following the above, then the only way to re-install Mcaffee onto your Vaio is to recover your Vaio back to factory settings using the Vaio recovery centre.. :slight_frown:
rugid22
thanks much thalamus cant seem to do it still but got anti virus software from woolworths dirt cheep as they have now shut gonna see how that wrks run by panda software i think so well see thanks any way. rugid22
Thalamus.
Champion
You're welcome rugid22.. :slight_smile:
