Memory card reader
grzs__
Memory card reader
Hi all!!!
I bought my Vaio fev days ago,
VGN FE41M has a build in reader for ms/mspro and a small memory card reader that can read fev othe card formats such as xd....ect
My windows however, cant find any drivers to install that reader, and it`s not working properly.
If someone had such problem, and somehow manage to solve it I would be very gratefull for any help in this matter.
Greg.
jroloywi
You use Windows Vista or Xp?
Because I use Windows Vista and I had the same problem with the momory stick reader...
A Vaio club member found the solution: I opened the "Gestionaire de périphériques" (in french (sorry): in english it's maybe the "gestion of peripherics") and in "Other peripherics", right click, and I installed the driver.
grzs__
Yes I am Vista user!
I couldn`t manage to solve the problem as u said because I do not quite know what you had on mind, and If u could be more specific, I think I might be succeded in solving this problem.
Tell me what uy had on mind, and where I can find in in the system.
I really appreciate your help.
Thank you,
All the best
Grzesiek
