I have a PCV-RS322 and I'd like to upgrade the memory to 1Gb. The spec sheet delivered with the PC says I have PC2700 DDR400 DDR SDRAM fitted. Which is odd, because according to all the memory manufacturers this doesn't exist.
I loaded SiSoft Sandra to interogate the memory and it reported I have PC3200 DDR333 chips which, you guessed it, don't exist either.
Can someone, preferably from Sony, tell me what memory I need to upgrade my machine? Explaining why the specs are wrong or, if necessary, how they're not? Regardless of any answer, is there some way I can DEFINITIVELY check what's in my machine?
jack :-#
According to www.crucial.com/uk the memory in your computer is DDR PC2700 CL=2.5 Non-parity
If you want a reply from Sony then your best bet is probably to forward your enquiry to them using E Support at www.vaio-link.com
