Hi, I have Sony Vaio PCG-FR315B. I would like to upgrade my RAM memory to 1024 MB (it is a limit of my computer). I have two slotes for memory modules. Can I use one memory module of 1 GB, or should I buy two times 512 MB?
Thanks for an answer.
I would buy 2 X 512MB because your model has a maximum capacity of 512MB per slot.
http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20PCG-FR315B
Instructions: -
http://support.vaio.sony.co.uk/tutorials/memory/memory.asp?m=1390&site=voe_en_GB_cons
Thanks a lot! As always very helpful answer!!!
