Hi, I'm re-installing XP to get something cleaner than the overloaded default XP and I have the following problem:
When I install the sound driver, I have a message at around 50% of the install that i have to load the Microsoft Bus driver prior to installing sound (realtek HD audio).
Where on eart can I find this thing?
Any help will be greatly appreciated.
I have just recieved my new FS115Z and one of the first things I did after creating the recovery disks (cheep skates) was to ditch the home version of XP that was sat on the laptop and load XP Pro... While loading the audio drivers I had the same problem, so I left that bit and looked in a folder that had some microsoft Hotfixes, two of which only work once you have installed SP2 and the third... suprise suprise was the hotfix to fix the problem with the audio driver... bang the computer started to look for the audio driver which I kindly provided in a silver plater and all works sweet now (just need to sort out the speed step stuff):smileycool:
Problem SOLVED !
http://downloadfinder.intel.com/scripts-df/Detail_Desc.asp?agr=N&ProductID=1861&DwnldID=7525
Now only remaining for me is to get proper trackpad driver (the one that displays the trackpad in the tray area)
