I have a VGN NW 20 SF.
I have not used word much, but it gives you 25 go's without a product key number. I now need the product key number. Does anyone know what is is or where to find it. Thanks
Solved! Go to Solution.
Hi Gorman1961
Sorry your going to have to purchase microsoft office to get a product key number.
Jeanette66
That is because it lets you try it out before purchasing the whole set of MS Office. It doesn't come free with any laptop or desktop you buy.
I hate this kinda crap from new laptops damn free trial software.
I recommend uninstall it all and then down load Open Office which is a very good free bit of software.
www.openoffice.org (its free even for business users unlike other free versions of stuff)
It will open majority of MS Saved documents new and old. Also allows you to 'Save As...' MS files as well.
