Missing color while capturing VIDEO INPUT
pingus
I'm trying to capture one of my VHS videos using a Toshiba VHS-Player connected to the VAIO desktop using a SVHS cable with Mini-DIN/Scart connectors.
Sound is OK. Imae not. The film is only black and white.
I'm using GigaPocket on a PCV-RZ102 VAIO desktop.
Any ideas how to solve this?
6 REPLIES 6
kee-lo_
Make sure you are capturing to PAL or NTSC according to the video's source.
robpaxton
Also have a look at http://pub173.ezboard.com/funofficialsonyfrm31 - Gigapocket is much more common in the USA so you may get more solutions there.
Regards, Rob
pingus
Hi KeLoo,
where can I change this?
Thanks in advance
kee-lo_
I'm not at all familiar with GigaPocket, its best to see Rob's link as there are a lot more GigaPocket users there.
pingus
I'm on the way ... :slight_smile: thanks for this hint.
kee-lo_
no problems
