Laptop details:
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-FE21M&os=7
Go to the above and download the relevant drivers for your laptop
These will allow the relevant shortcut buttons to operate
Each driver has a description of what it does when you click on the download link but i think the ones relevant to your issue are
Under Vista Utilities tab:
Sony Shared Library
Sony Utils DLL
Vaio Control Centre
Vaio Edit Components
Under Drivers tab:
Alps Pointing Driver
Alternatively go to the Originally Installed tab on the same site and download the two zip files which have all the relevant application/drivers for you pc
I did the same for my FE41M by clean installing Win7 and took some time to locate all the drivers but once i did it works a treat and is real fast. The main problems i had were identifying 64bit drivers for the memory card slot and webcam
Good luck, if you get stuck post here again
Peshyxp,
Thank you for your detailed info. I got all the files downloaded and installed, but.... Still no success.
Is there a certain order in which these drivers, utilities and the like have to be installed?
Only once I saw the brightness bar on the VAIO display after I selected Fn/F5,6 (brightness control). It did not control the brightness however. I cannot remember how I achieved this. The other functions were still not working. So, I installed again drivers, utils and so on. After that, same result. I.e. not working.
I keep trying.
If you have another advice it is most welcome. Thanks again for your help.
Have a nice Eastern.
Wim
Message was edited by: TechniekCoach
