Missing software... WINDVD and Roxio.
profile.country.sv_SE.title
FredrikSandgren
I have just taken my VPCZ12Z9E/X out of the box and i am missing some software that is supposed to be included. WinDVD and Roxio is mainly the ones i need.
Can i get the dvds or download them somehow?
Thalamus.
Champion
Hi FredrikSandgren,
welcome to Questions & Answers..:smileyhappy:
If you believe you are missing some of the pre-installed applications then you'll need to contact vaio support as the Sony supplied software is not available to download..:smileysad:
To contact vaio support either click on Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Thalamus.
Champion
Hi FredrikSandgren,
Then click Log-In
