Trying to burn a DVD on my FR315S, using Click-to-DVD. But it's not recognising my disks, I have tried two different makes one cheapo the other Philips +DVD RW disks, no joy.
Have looked at the disk via, Start, My Comp, DVDRw Drive and it displays; in Details, Free Space 0 bytes, total size 0 bytes. (this is a new disk out of the wrapper)
Cd player works okay, DVD Writer worked okay couple of weeks ago, but only after trying few disks, (cheapos, I thought they were the problem so I bought the Philips, which I have used before. )
I have all downloads updated from Viao-link etc.
I have also just uninstalled dvd drive and re-installed. Still no difference!
Any ideas?
I can't find a list of drivers that should be installed - any suggestions??
Hi
Yes, I've checked the drivers, but unfortunately they don't identify which relate to dvd/cd rom etc. Every time I have tried to follow a thread at support, or speak to a telephone support person, we end up at the "backup your data and restore" scenario. Not too helpful as I've got about a million programs installed (only a slight exaggeration) and if I have to try and reinstall my wireless network having forgotten the passwords, I'll probably end up shooting myself.
It's listed under "Optical Drive"
Latest is version 1.5g
