Mouse click problem: VGN-SZ5VWN/X
matthewhambly
I have a problem with the left click of my touchpad. It does't work most of the time unless you press it quite hard, and even then it doesn't always register the click. It also sometimes double clicks even when you only press it once.
Basically it sounds like it is broken unless anyone has any other ideas?
I wouldn't really expect this from a £1899 laptop, that I have treated perfectly. Never spilled anything on it (I never even bring drinks of food near it!)...
I bought this in May, so what are my options? Will I be able to get a replacement, a repair or is there nothing Sony will do?
anzagi
Under the standard 12 month warranty, I would think Sony will have to repair it (and if hey can't then replace it)
