Move Sonic Stage Based Tracks to a new hard drive
sburdin
Hi all,
I've just installed a new hard disk into my PC and I want to move my Sonic Stage tracks\library over to it. Is there any way I can do this? I suspect I may have to use the Backup facility.
Cheers,
Stephen
chris_lewis
I am not sure if this is possible, Atrac doesnt like being moved!
Still if you want to have a go, the backup is as good a place to start as any!!!
The DRM will stop you doing anything else, after you have done the BU, I am guessing you will need to reinstall SS on the new drive before attempting the transfer too.
C
MadarbWoT
the backup should prove enough for you but it will cause you trouble and take some time,so you can think about copying or cutting all the files into the new drive and then deleting the sstage library to reenter them from the beggining,still very time-consuming!
sburdin
Thanks to you both for your replies.
I suspected the backup facility would be my only option.
Cheers,
Stephen :slight_frown:
