I have a PCV-RZ322(CE)S/N 28476150-5001003. Graphics card is NVIDIA GeForce FX5600 with latest drivers and OS is XP Home with Service Pack 2. The desktop has both analogue and digital display outputs which both work.
I have a Sony TFT (SDMX52DVI) and a HANNS-G TFT (HW191D). Both monitors have analogue and digital inputs but I seem to be able to only have one monitor working at a time?
In the Nvidia control panel there is no option to select multiple monitor set up showing.
Does anyone know if this system supports multiple displays as the option to set this up is not showing under Control Panel/Displays/Settings in XP?
John
Hi John,
It doesn't look like it is possible.
Have a look in your manual:
