My vaio FE41Z is not detecting any wireless devices
satyaannareddy
I have recently bought this vaio FE41Z with vista home premium. I have been using the bluetooth to transfer the images successfully. but yesterday when I have tried to configure the wireless router it hasnt detected the device at all. Have noticed that the wireless connections are showing as not connected but they are shown as enabled.
when performing windows diagnose utility it says you might not have switched on the wireless capability and its seen on the front side of the laptop. but its enabled and I can use the bluetooth properly.
Can someone please help me sort this out.
kee-lo_
Try turning bluetooth off while using WLAN
