do not know how I would install the driver after format at my vaio???
When you buy the computer or the vista driver cd did not have
Hi deluxo,
welcome to Club VAIO..
Yo should be able to download the drivers and utilities for your Vaio from Vaio support..
To open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 2: Select your VAIO model, next to Select Model Category - Select your model from the drop down list.
Then next to Select Model.
Then click Log-In
Once logged select Downloads followed by Originally installed..
Or
If you wish to restore your vaio to factory settings and your Vaio has a hidden HDD recovery partition, so as long as it has not been deleted when you formatted your VAIO, then you should be able to recover your Vaio back to the original installed OS and programs just as it was when you first used your Vaio.
To do this Start your Vaio and when you see the Vaio logo screen press F10 repeatedly this normally would start the recovery process..
