My VGN-FE11M in big big trouble!:(
rcas
Hi, can anybody help me to solve the problem stated below?
I download the BIOS R0122S5 from the vaio official site yesterday and follow all the instructions to install it, when i restart my VGN-FE11M, it can not entry windows, the screen shows nothing, only the Power, Battery indicator and the Num, Caps, Scroll lock indicators are turned on.
Is there any method to fix this problem?
5 REPLIES 5
Thalamus.
Champion
Hi rcas,
welcome to club VAIO.?
Are you able to boot into the BIOS.?
Are you able to boot into safe mode.?
Do you hear any HDD activity.?
If so try connecting your Vaio to an external monitor, do you still have the same problem.?
rcas
Hi rcas,
Hi, Thalamus, thx for ur reply! :slight_smile:
I don't think it can enter into the BIOS and the safe mode, it seems to me that it can't recognize all the hardware and the HDD seems act nothing cos the HDD light did not turn on and have no sounds neither! :cry:
Thalamus.
Champion
Hi rcas,
I suggest you contact Sony Vaio support, you can do this either by phone or via e-Support, use the following link to find the contact details: Sony Vaio Support
rcas
Hi rcas,
Hi Thalamus,
I'll contact them on monday and I really appreciate for ur help, thx alot!:)
Thalamus.
Champion
Hope all goes well, could you let us know the outcome please.. :four_leaf_clover:
