need bluray drivers for vgnar21s
kad1999
Hello i have just tried updating a bluray file.
It deleted my old driver files.
Where can i download the original from?
thank
kad
4 REPLIES 4
AR21S Preinstalled Drivers and Utilities
You will also find a firmware update for your drive on the same page - make sure you use the right one !
:wink:
kad1999
:wink:
Wouyld you be so kind and writ eme down the link.
For the exat drive so i will not mess up again?
please regards
kad
kad1999
:wink:
please regards
kad
I have just gone there downloade drivers and utilities.
Canot find bluray drivers or programe can you help/
Tell us exactly what you did.
You tried to update WinDVD - is that right? Have you also tried to update your firmware?
I think you have two versions WinDVD for Vaio and WinDVD BD. Did you try to update from within the program by choosing Help -> Update or did you try to download a brand new copy of WinDVD 8? It sounds like you have Uninstalled the Sony WinDVD BD player - this supplies the drivers for the BD Drive. I don't think you can download this.
Have you made a set of Recovery Discs? If you have you can possibly reinstall WinDVD BD from these. If you can't reinstall the individual program, you may have to completely restore your drive C: to factory condition to get it back.
It is difficult to suggest the way forward when I am unclear exactly what you have done. Can you list what you did?
:thinking:
