Net-MD problems
olo
Net-MD problems
The Net MD drive of my PCV-RX413N is playing only three songs of a record. After this it start to searching (without success) and switch off. It is impossible to reactivate the drive (only by rebooting the computer) :slight_frown:
Is it a Software or a Hardware problem? What can I do?
Thanks for help
Olo
EzDoezIt
I don't know if :arrow: VAIO Link Solution 31643 is of any help, but it also talks about the magic number 3.
Also have a look at these :arrow: search results.
RobertStalker
If it works for three songs, then it searches, means the software is searching for data that is no longer available either by deletion or corrupted data. I would certainly concentrate on the software.
