new battery for old Sony Vaio
chrissie_dee
Where can I buy a new battery for a Sony Vaio VGN-FE41S?
Thalamus.
Champion
Hi chrissie_dee,
welcome to Questions & Answers..
You  should be able to purchase a replacement battery from Vaio support or  possibly from one of Sony's authorised repair partners, to find the  contact number for Vaio support.
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab, then Phone support.
To locate the nearest Sony service partner click on Out of Warranty Service tab
You  may find cheaper prices for a replacement battery via Google but be  aware than some retailers sell non Sony compatible batteries with the  same battery model number..
Thalamus.
Champion
Hi chrissie_dee,
Then click Log-In
