New question about AC adaptors
mattemanne
Ive a VAIO S5HP, and my adaptor is an AC19V10, v:19.5V i=4.7A.
I see on the web there are plenty of different original vaio ac adaptors smoller then mine.
Some timethe only one difference is that the current is i=3.3A
Can I buy and use one of these?
Or do oyu know if there are smaller ac adaptors for my vaio?
Thanks.
Matte
4 REPLIES 4
kee-lo_
I would stick with the same 4.7A with 19.5V, you can seriously damage your VAIO by using different power
mattemanne
:cry: but if I want a smaller power supply?
any chance?
BartK
If your Vaio asks 4.7A you cannot connect a 3.3A since that will MELT your AC... The fact that they bundle a big AC means you NEED a big AC and cannot do with a small one.
kee-lo_
Personally I wouldn't risk it, as Bart says it can melt, and could be dangerous to you and your VAIO.
