Hi anyone help I am getting a blue screen with this message nmi parity check/memory parity error I have a sony vaio VGN-NR21Z. Its very random as to when it does it have run adaware and my anti virus software and its coming up with nothing. Any one help with fix.
Many Thanks
Hi mulford and welcome to Club Vaio.
The messages you are getting indicate a physical memory parity error.
This can be caused by loose or faulty RAM modules.
1. Check the modules are seated properly - follow this guide http://support.vaio.sony.co.uk/tutorials/memory/memory.asp?m=3120&site=voe_en_GB_cons
2. Update your graphics driver (GPUs have dedicated memory too). Try this one: -
http://www.laptopvideo2go.com/drivers/vista/176.37
3. If these don't do the trick try running a memory diagnostic tool like MEMTEST to try to identify faulty modules
Hopefully one of these will help - if not consider reinstalling the operating system.
