I have a VGN AW11 Z / B notebook (widescreen display, full HD resolution).
Super-TFT panel and good voice ....but.
my problem is:
If you click on the preinstalled program WinDVD on the full screen mode, the picture hangs in the upper left corner and fill only about two-thirds of the screen.
it is probably the limitation of the google or vista-sidebar. apparently, the WinDVD player a conflict with the other preinstalled softwares:
this had to at a notebook just does not happen, which full_HD with a 1920x1080 resolution comes on the market.
powerDVD8ultra with the test version I've tried, and so it went ......
why is not with the purchased software by sony (regarding inter-video)?
Otherwise, the battery also so weak that you barely a blue ray film with a full length play.
Can anybody help me?
tomcater
