- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
No Sound from my Laptop
Can anyone help with my VPCEB4L1E laptop, their is no sound coming from the internal speakers it only works with external speakers, I have tried uninstalling the driver and reinstalling it, but the icons etc keep saying it is working their is no problem. this has been going on for a few weeks now, I have also tried going back to a previous date.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi nettlehill73,
Assuming that the external speakers you are using are plugged into the sound out jack and not HDMI or SPDIF then it would seem that there is a fault with the internal speakers.
If your external speakers are not plugged into the sound out jack then check Control Panel > Sound and make sure that Speaker/HP is selected as the default playback device.
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Rich
Thanks for you reply, I have checked and the Speaker/HP is selected as the default playback device. Still saying this device is working properly, not sure what the next step is
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi mo0gzy,
As you have already tried reinstalling the driver, a system restore to a date prior to the problem, and Speaker/HP is set as the default device you should contact Support - assuming of course that your machine is still in warranty.
Your only other option is to return the machine to factory settings which Support may ask you to do anyway before considering a collection for repair.
Rich
