I've managed to connect my AR31S to the TV via a 1.3 compliant HDMI cable and have managed to use the TV as an external monitor. HOWEVER... I just simply cant get the sound to go through the HDMI cable for any source, be it MP3, Blu-Ray, CD or whatever.
I am having similar problems with the optical out connected to my AV amp. I can get sound for music on my HD but thats a bout it.
I know HDMI supports both sound an dvideo, but its hust not having any of it! This is driving me insane - any sugestions please?
Cheers.
sorry no answer, cos I have same problem also same model AR31S.
anybody else have theirs working with sound?
Hi hilliert,
welcome to Club Vaio..
There is an update that should rectify this problem..
This update is only available via the Sony Vaio Link Download page..
Use the following link to download the update: HDMI Software 071025a
Yes - done . Thank you!
You would not know how long this has been peeing me off! Why did it not appear as a regular update given that its suggest a widespread defect?
Oh well - alls well that ends well I suppose.
Thanks again. :smileygrin:
You're welcome hilliert..
Guys
I just purchased a FZ21M which also sports a HDMI - unfortunately it seems that I can only get STEREO output from this port into my Onkyo 805 amp - please tell me this is NOT the normal operation?
I purchased this laptop primarily for its ability to output Blue-Ray into my projector via my HDCP compliant AMP with 5/6.1 sound.
If it cant do this then I am very dissatisfied and would seek to return it.
Any points I consider - I must have missed something?
Many thanks
Tone
