Well,I got the Windows 7 upgrade disc's from sony on 26th oct ,but after fiddling with it for few days, I found out that there is no way we can make recovery discs .hmm
This means that if windows 7 gets corrupted or crashes ,I will again have to restore Vista (via recovery partition or recovery disc ),then use Windows 7 vaio upgrade discs to install windows 7 .
This takes a hell lot of time .More than 3hours to install Windows 7 :(.is there anyway to get recovery partition or make recovery discs for windows 7 .
regards
Abhinav
no reply 😞
thanks for the reply
seems like I will have to purchase third party software like you have recommended me
