Due to expire soon on my AR61e and I had already purchased Norton Internet Security 2008. What is the best way to install? Should I uninstall the 360 first? Reason I'm asking is that when I tried to install it when I got the notebook it didn't seem keen to install it with the 360 there.
Jim
Hi Jim,
I would think it best to uninstall Norton 360 if you had a problem earlier..
Here is Norton guide on the procedure..
1 Click Start > Control Panel.
2 Do one of the following depending on your operating system:
* In Windows Vista, click Uninstall a Program.
* In Windows XP, double-click Add or Remove Programs.
3 In the list of currently installed programs, click Norton 360 (Symantec Corporation), and then click Remove or Uninstall.
4 Click Remove All to confirm that you want to uninstall the product.
5 In the Subscription Period Warning, click Next.
6 Click Next.
7 Click Restart Windows Now (recommended).
Your Norton program is not fully uninstalled until you restart your computer.
8 Click Finish.
If you have a problem uninstalling Norton 360 then you can download and run the Norton Removal Tool, use the following link to download: the Norton Removal Tool ..
As ever, quick and comprehensive help. Thanks Thalamus.
You're welcome Jim..
I am currently using Eset Smart Security, it's easy on resources, very effective and I recommend giving it a go.
A free 30-day full working trial is available here
It hasn't caused any problems at all on my FJ3 running XP.
