Hi there i was wondering if anyone could help. I own a a317m and i accidently deleted the nortan anti virus protection software. Now if i go into restore applications if does not come up on the list, does this mean that i will now have to restore my whole pc?
thanks
Norton is preinstalled on your system. If you deinstall it then you can't reinstall it. Yes, you need to restore the system. But there should be a restore point.
It only lasts 90 days, you're best either
1) Getting Norton Internet Security on CD
2) Getting ZoneAlarm Security Suite
3) Getting ZoneAlarm Free and AVG Free Edition.
