notebook screen
petestenny
notebook screen
Simple question what's the way to clean a notebook screen and using what?
11 REPLIES 11
CaseMillennium
I use a microfibre cleaning tissue and eventually some water (not too much!!! - mostly a dry cleaning tissue works great for things like fingerprints or something like that).
Twisted-Rizla
You can use wipes from any stationers or comp shops but I find they are not really moist enough. I use a lint free cloth moistened ina bit of water.
kee-lo_
Same here
1234567ty
I use KLEAR SCREEN, which was recommended to me by keelo (merci), and it works a treat. You should be able to get it on amazon.
It does: PDA's LCD, TFT, CRT, so it can do most things.
Harry
profile.country.de_DE.title
seb21__
LOL, I use a simple cotton cloth with a bit glas cleaner (whitout alcohol). That's all, and I have no problems with the screen.
jammold
GLASS CLEANER?!
Hmmm not sure about that Seb.
I use a Tesco's dishcloth (the soft fleece type), dampened in a small amount of water, and clean the screen with the minimum of pressure.
seb21__
Mmmh, I had never problems.:smileyconfused: But I use a cleaner without alcohol and color.
Eugenepang
i used cloth that used for cleaning spec. :smileygrin:
mvanwambeke
Or you can use these static electric cloths ... like swiffer.
So you can avoid and LCD screens worst enemies
- water ( fluid in general )
- acid(s)
