ntsc on 2nd monitor & no way to change it (Help pls)
moondjno1
i have just purchased a new vaio with a nvidia g force go 7600 with 128 mb dedicated graphics set up dual monitors as i want too run a tv as a desctop i do have it working as a desctop but its in ntsc and i need pal so its black & white. when i go to detect the tv it cant find it so i selected force tv . i have put several diferent tvs on the s video out to composite adaptor it cant find any of them even a brand new tv i just brought. having said that the picture comes up on all tvs its just ntsc . so when you go too settings to change regions you cant cus it dont pick any of them up so you can change them, please is their a fix for this problem before i jump of the bridge trying to fix it. all responses welcome. i think it may be software fault but im not sure.
0 REPLIES 0
