NVIDIA geforce 8400M GT drivers for 64 bit Windows7
zilrakst
I have Vaio VGN-AR51J for several years, with Windows Vista. Now I decided to upgrade my current OS to 64 bit Windows 7 Enterprice.
At the moment I`m looking for Nvidia Geforce 8400M GT  graphic card  and memory card Memory stick reader/writer drivers(Magic gate) drivers.
Thank you!
7 REPLIES 7
No guarantees as Windows 7 64-bit is not supported by Sony on your model - but I would try the following drivers: -
nVidia Graphics Driver 8.15.11.8540_0910130 64-bit from the Windows 7 downloads for the VGN-AW11Z from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-AW11Z_B&os=10
I know the AW11Z has the 9600M chip but I would expect it to install.
The memory card drivers are not OS dependent so you just need a 64-bit Texas Instruments Memory Card Driver.  Sony have made someunofficial Vista 64-bit drivers available.  I think you need Download: EP0000140007.zip from here: -
http://www.vaio-link.com/os/vista/64bit/
:wink:
zilrakst
to>> blencogo.
memory car driver not working from sony support site, even is not a driver.
I downloaded drivers for texas instrument pcixx12 from : http://forum.vista-driver.org/index.php?showtopic=285&pid=1871&st=0&#entry1871 , and now my memory card reader working properly.
zilrakst
What else drivers  I can try  for 8400m GT?
Hi Zilrast,
What is still not working?
:slight_smile:
zilrakst
Just found 8400m GT drivers from Vista 64 and instaled. Working! Happy now :slight_smile:
There is link for vista 64bit drivers : http://dls.update.sony.net/pub/oth/64/EP0000146244.zip
Now left to find drivers for: DVD eject buton; mute; S1 and S2 butons; play,stop,pause ,etc butons.Any ideas where from I can get drivers for these butons?
Apart that, everything is working :slight_smile:
You will need to find some 64-bit Sony Utilities to get these to work.  I don't think these exist for your model so you may have to try them from another Vaio.
It sounds to me like you need: -
SFEP Driver
Sony Shared Library
Vaio Event Service
Good Luck!
kas49.
Czy jest aktualizacja do NVIDIA geforce 8400M GT drivers for 64 bit Windows10 ?.
