- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
December 2009
December 2009
Opening VGC LT1M Case
Anyone know the procedure for accessing the hard drive in a VGC LT1M?
I want to 'upgrade' to Windows 7, but also change the hard drive at the same time to a larger one. (I know it's possible to add a further drive, but using a newer low power drive is a better option).
Many thanks,
Colin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
April 2010
April 2010
Yup,
I know how you can access the drive.
in simple, pull off your back lid, then unscrews all the screws at the back (not the RAM)
use the two plastic thingies at the end to clip your wires as a way to pull open the case.
becareful not to snap anything.
There you go, you now have access to your 3.5" HDD drive. TADA!
hope it helps.
