part number for dc power jack replacement Vpcec2c5e
duncandl
Hello,
My power jack is damaged, does anyone know the part number so i can get a replacement? The vaio is
Vpcec2c5e.
Thanks.
Duncan
(UK)
LaptopSpecialists
On the Sony Vaio VPCE series laptops, the part number is usually on a little white label on the power socket cable. Saying that all VPCEC power sockets are the same, so if you just go onto Ebay or a similar site and search VPCEC "dc socket" or "dc jack" you should get some results. But a part number for this is 356-0101-6592_A or A1766509A.
Hope this helps.
Message was edited by: rich912
Advertising with link to commercial website irrelevant to the thread
