Installed fine on old Notebook but on S2XP the device reports that it is not intended for this device and despite installing the IDE / ATAPI driver is not recognised. Checked the drivers on my other notebook wich reports it is using ATAPI.SYS and STORPROP.DLL, both of which exist and appear the same on my VAIO. Am now at a loss and the only evidence of my hardware is the report that SanDisk SDP device drivers are not installed, error code 28. Any suggestions gratefully received.
Is it a USB device?
Try SanDisk's website too.
No it is a PCMCIA card CF Adapter. Have looked on the Sandisk website but everywhere I look says that it should work without drivers, as it does on my other notebook with apparently the same system files. J
