Pccrs704 windows media center reports no tv tuner found
len112
I upgraded to vista hadn't used the tv function before ,when I try to set up the tv tuner it says no hardware has been found , is there a way to fix this as i'm pretty sure that there is a tuner installed
len112
I am still not able to solve this problem , anyone have any advice please ?
Hi len112,
The TV tuner you have is a Sony MPEG Encoder Board and will only work with Vaio Zone software - it will not even work with XP MCE let alone Vista MC.
However, all is not lost because Sony have produced a version of Vaio Zone that works with Vista.
Have a look at this thread - it is about the V2S but it will give you an idea of what is involved: -
http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=40164
You can find all the Vaio Zone software for your model available for download here: -
http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=1&s=PCV-RS&m=1755...
:wink:
