pcg-7185m has locked me out of preinstallled office version 2007
stringe63
i have been locked out of my preinstalled version of office 2007 - i am unable to do anything except print off pre-constructed documents.. i am unable to construct any new documents ony description, or edit previous documents.
it still asks for the product key as i attempt to open the program - the key i am typing in is the one on the underside of the notebook - i am assuming this is correct (or am i being a dumbass!!!???)
Anyone any ideas on how i can rectify this would be gratefully appreciated
regards
steeve
Thalamus.
Champion
Hi steeve,
the product key that appears onn the base of your Vaio is a generic OEM key that Sony use..
Have you already activated the MS Office trial.:smileyconfused:
If not ave a look at the following guide -  Use the Office Activation Assistant wizard to activate your Office 2007 trial
Thalamus.
Champion
Hi steeve,
