pcg 8131m
drnokia
pcg 8131m
i have the above and would like to know if it has a spare hard disk bay, used to have a ar41l and had it with that and would like to transfer the drive to new notbook, if this does not could you please tell me which in the aw series does have the bay and connections.
Thalamus.
Champion
Hi drnokia,
unfortunately you have quoted the chassis number which makes it difficult for us to help without the model number.
If you are not sure of the model number then the following link may help: I cannot find my VAIO model...
