- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
PCG-FR415M
Hi
I have a PCG-FR415M that is about 3years old. I wanted to know if there is a wireless card that is compatible with it. I'm moving into a new flat and its wireless enabled while I used to use cables. I looked on the vaio accessories page but couldn't find anything.
Thanks for your help
Sara
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Assuming you have either (or both) a PCMCIA slot or a USB slot then you can buy a wirelss card/adapter for either.
If your laptop does not have USB2 then a PCMCIA may serve you better speed wise, although plain USB may cope admirably with the throughput of wireless.
As to brands - I would stick with a well known brand such as Belkin or Netgear.
I have in the past used Netgear PCMCIA cards on former laptops and they worked fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Sara and welcome to Club VAIO.
There are LOTS OF WIRELESS CARDS and most of them are compatible with your Vaio.
I think I would try to find out what make of wireless transmitter is installed in your new flat and buy a card compatible with that. But in theory any wireless 54Mbps b/g card should work but ask other users.
EDIT: Sorry William - you are too quick for me!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No worries - Valid point about asking flatmates!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks very much for your help!
:smileygrin:
Sara
