johnmule
PCG FR415s RAM
i have a Sony Vaio PCG FR415s and want to buy an new Ram.
I'm allowed to buy one stick with 1Gb RAM or i've to buy two sticks with 512Mb Ram, because the max. capacatity is 1GB.
Thanks for the answer!
John
kee-lo_
Crucial.com is a very good place to buy RAM, and I'd suggest getting the 1x1GB, so in the future you can expand it easily and quickly
Thalamus.
Champion
Hi johnmule,
Welcome to Club Vaio, :slight_smile:
The maximum Ram the FR415S can support is 1024MB and I seem to remember that the maximum module size supported is 512mb..
Therefore if you wish to upgrade your Vaio's RAM to the maximum you will need to buy two 512mb modules
If you decide to upgrade here is a link on how to upgrade your Vaio's memory...:smileywink:
frannys
Agree with the 2x512.
