PCMCIA card with Firewire 800 - Compatibility with a Vaio GRT 816S ?
Tourniaire
Hi everybody - Can I put a PCMCIA card including a Firewire 800 port on a Vaio PCG-GRT 816S, I have bought on January 2004 ? Is the machine compatible with this high speed port ?
Thanks for your help.
10 REPLIES 10
profile.country.de_DE.title
seb21__
There should be no problem.
They are 3 types of PCMCIA cards. (different size)
    Type I : 3 millimeter
    Type II : 5 millimeter
    Type III : 10.5 millimeter
Type III is really rare today and was mostly used from harddisks.
Your VAIO supports them all.
So, buy it if you need it. It works.
kee-lo_
They're Type II
Let me know how you get on with that
rich912
I bought one for my son’s Dell recently, works a treat!
Have a look here.
Go n-éirí an bóthar leat
kee-lo_
Does it make transfer any faster Rich, or does the hardware need to support firewire 800?
seb21__
If Sony use internationan standards, then it should work.
Tourniaire
Thanks Rich for this reply. Your card seems to be Firewire 400 and not 800. Am I right ?
rich912
On closer inspection of the picture I think that you are right. I thought that it had one 400 and one 800 port but as my son is away at present I can’t physically check it. As Seb rightly says, there should be no problem unless Sony has departed from international architecture, which I doubt. Windows 2000 and XP support Firewire 800.
feederfan
I didnt know PCMCIA could support transfer speeds that high!
seb21__
It support much more. Correct me if I'm wrong. But it's up to 132MegaByte per second. (in DWORD mode).
For those which are interestet........
.................click me
