Hello,
I own a PCV-RS502. Everything seems fine, but I frequently get the same problem.
After some hours of uptime, my LAN connection freezes.:smileyconfused:
I've got 2 PC's connected to the Internet through an ADSL Router (configured via DHCP).
Whereas of of them is still able to view web pages, my VAIO can't. So I guess it comes from the computer.
I can still ping websites ang get responses, hear music through shoutcast, but my browser can't open any webpage (despite the two PCs get the same DNS from the ADSL modem) .
-I tried to reboot my ADSL router,
-I tried another browser (Firefox),
-I switched off my firewall,
-I tried to restart the windows network service,
it didn't work.
The only thing that works is to reboot the computer...:smileycry:
Can anyone help me ?
TIA.
:smileygrin:
Netgear products are great.
Hi all !
I am connected to my router with a RJ45 wire. I use the built-in RJ45 port of my motherboard.
My computer is running XP home SP1a.
The problems I encounter are not wireless related, except that my router has this feature ; but I actually don't use it frequently because my computer and my router are very close.
Now I am *waiting*:smileytongue: for my problem to reappear.
I want to try putting IP addresses directly in my browser instead of names to check if it's a DNS problem.
Else I'll try to add another network card to my computer to determine where does the problem come form...
[Now two days since the last "crash".] Thank you for your help.:smileygrin:
NB : I know it's not the point here, but don't hesitate to correct my sentences, I would be glad to learn more about the english language.
"No news, good news..."
Common french proverb; probably dull, I know, but that could be the end of my issue. :smileygrin:
I didn't change any hardware since then, and only did minor changes among my software...
But everything is working fine since my last message.
Anyway, thanks for all your help
Thats great news.
