PCV-RX201 1.6 - 2.4Gz
Innocent
Hi all was wondering if any1 has upgraded there cpu and if so how complicated is it. Can i just pop 1 out then place 1 in or not.
PLEASE HELP
kee-lo_
You have to make sure they are the same socket size, type (P4 / Celeron) and the FSB is the same. Check these in your manual before doing anything.
