PCV-RX755 Do Vaio desktops support power supplies
ZiPpY-Da-HamSTa
In need a 300-400 watt power supply and my friend told me that I need to order it directly from sony, is this true? Or can i take a trip down to Best buy and buy a power supply from there?
robpaxton
A lot of Sony desktops use small power supplies - it is normally the size that causes problems.
ZiPpY-Da-HamSTa
well now i donT want to go to best buy and spend 60 dollars on a power supply that doesn't fit...
Does anyone have any ideas about wat the price is from sony? (for a 350-400 watt power supply?)
