I have bought recently a VGN-FW11M vaio and tried to play a blue ray film ("300").
WinDVD BD (intervideo) opened, but after few seconds I got this message on a black screen:
"your display environment does not support protected content playback"
Can someone please explain to me why this happened and more importantly what should I do to watch this film and hopefully many others.
As I am a new user of this laptop I am frustrated this things happen to a brand new and supposedely advanced / state of the art machine..
Thanks for your attention
p
Hi xexakis,
welcome to Club VAIO..
Are you trying to watch 300 on your FW11M's screen or an external TV/Monitor.?
Hi I have the same problem im using a VGLX302 connected to a LCD Sony Bravia. The palyer was not able to play.Man of Hulk nor any other old blue ray title. It had been able to play old titles before Spiderman Rise of Silver Surfer etc. Following a complete reinstall it continues not being able to play blue ray tiles the above message appers when trying to play Iron Man or the Hulk
I would apprecitae any advice you had to offer. Thanks.
Az
Hi xexakis,
welcome to Club VAIO..![]()
Hi
My recovery utility does not include WinDVD. Any other suggestions will be welcome.Thanks.
Az
May be your screen do not support full HD technology it is mean Pixels 1920x1200 ?or your computer's sdram is less than 2GB
Hi
Thanks for the advice I have solved the problem please see my other posts.
Az
Glad to read that you have solved the problem xexakis..
If this does not fix the problem then please we suggest you re-install WinDVD from the Recovery partition using application recovery by doing the following:
1.Click Start,
2.All Programs,
3.VAIO Recovery TOOL,
4.VAIO Recovery Utility
5. Select Recover your Computer
6.Click on Options.
7.Click on Recover Specific Applications that were preinstalled
You will a list of all pre-installed softwares, select WinDVD, then install.
