Please help in VAIO PCG-K315M (2004 model)
FirePlayer
Hello!
I have a problem ... :slight_frown:
Maximum memory on a laptop VAIO PCG-K315M 1gb
I bought two 512 MB memory pc-2100 sodimm installed in the laptop, but the laptop shows that costs only 512, though the program "Everest" says installed two 512 MB memory ...
Then I went and bought just in case two more memory to 512 megabytes, but pc-2700, but nothing has changed ...
Installed memory Pc-2700 at 1 gigabyte, but it shows that only allows 512 megabytes ...
Tries to call in those. support, but unfortunately did not work, then the receiver will not take, then sent to a service center, and there do not take up!
I need all-only consultation, how to do so to show the 1 gigabyte of memory!
In Bios and windows! :bulb:
In advance, thank you very much! :handshake:
10 REPLIES 10
Hi FirePlayer and welcome.
Your Vaio needs 2 x 512MB x DDR PC2700 CL=2.5 Unbuffered NON-ECC DDR333 2.5V
Check the exact specifications as not all makes are compatible.
I have 2 x 512MB DDR PC2700 modules in my K315 which work OK. I bought my memory here: -
http://www.crucial.com/eu/store/listparts.aspx?model=VAIO%20PCG-K3x%20Models
:thinking:
FirePlayer
:thinking:
I now Memory SODIMM DDR 512MB PC2700 (333MHz) Kingston (KVR333X64SC25/512) - this memory does not work?
When I put two 512 MB I have shown that they are working half. Instead of 1 gigabyte in the amount obtained from 512 megabytes to 512 megabytes of two
FirePlayer
And this memory I have installed two of 512 megabytes, but nothing has changed.
Is it bad or characteristics are not they?
Name 512MB DDR PC2100 SO-DIMM CL2.5 Kingston ValueRAM
Code KVR266X64SC25/512
Manufacturer Kingston
Type of DDR memory
Standard PC2100
512 MB
266 MHz
Teh.ispolnenie SO-DIMM
Registered No
Parity Non-ECC
Number of contacts 200
Profile normal
List analogues
References for the production of module
Organization. module 64Mx64
Organization chips Unspecified
Type of chip Unspecified
Access time is not defined
Time flush Unspecified
Bitnost Unspecified
CAS Latency 2.5
Power 2.5V
Number included Unspecified
OEM PartN Unspecified
OEM Vendor GENERIC
Timing Unspecified
The PC2700 modules should work OK.
All I can think is that one of your slots is faulty. What happens if you put one PC2700 512MB in one slot only and boot. Then take the memory out of that slot and put it in the other slot and boot.
Do they both say 512.MB?
:thinking:
FirePlayer
:thinking:
not tested 512 megabytes of memory ...
We have installed two memory at 256 and they show the amount of 512 megabytes
are characteristics of the PC Wizard:
    > Physical Memory: 512 MB DDR-SDRAM
>> General Information
SODIMM1 (Bank 0): 256 MB - SODIMM
SODIMM2 (Bank 1): 256 MB - SODIMM
>> Information SPD EEPROM (SODIMM1)
Manufacturer: Samsung
Part Number: M4 70L3224FT0-CB3
Serial Number: 080E4889
Type: DDR-SDRAM PC-2700 (166 MHz) - [DDR-333]
Size: 256 MB (2 rows, 4 banks)
Module Buffered: No
Module Registered: No
Module SLi Ready (EPP): No
Width: 64 -??
Error Correction Capability: No
Max. Burst Length: 8
Refresh: Reduced (.5 x) 7.8 μs, Self Refresh
Voltage: SSTL 2.5v
Prefetch Buffer: 2 -??
Publisher: Week 69 of 2004
Supported Frequencies: 133 MHz, 166 MHz
CAS Latency (tCL): 2 clocks @ 133 MHz, 2.5 clocks @ 166 MHz
RAS to CAS (tRCD): 3 clocks @ 133 MHz, 3 clocks @ 166 MHz
RAS Precharge (tRP): 3 clocks @ 133 MHz, 3 clocks @ 166 MHz
Cycle Time (tRAS): 6 clocks @ 133 MHz, 7 clocks @ 166 MHz
>> Information SPD EEPROM (SODIMM2)
Serial Number: 080D4888
Module Buffered: No
Width: 64 -??
Voltage: SSTL 2.5v
FirePlayer
:thinking:
precisely in the morning did not have time to check after work required tests are two slots, and write!
FirePlayer
could affect the company name of the manufacturer of the fact that does not show the size of memory?
what - NON ECC?
FirePlayer
I checked!
The memory of 512 megabytes - works as 256 megabytes, in both slots
I think the problem in the memory, but still want to hear the advice!
information from Pc Wizard: (set memory to 512 megabytes)
>> General Information
Manufacturer: Kingston
Part Number: K
Serial Number: 7D14D02D
Size: 512 MB (1 rows, 4 banks)
Module Buffered: No
Width: 64 -??
Voltage: SSTL 2.5v
Publisher: Week 37 of 2009
>> Memory Controller Information
Memory Controller: System Memory
Number of connectors: 2
Max. Module Size: -2097152 KB
Where are you getting the figures from?
Read the installed memory figure from the Windows Operating System - not from some external program: -
Start -> Control Panel -> System
On the 'General' Tab at the bottom, how much memory is Windows actually using?
:thinking:
