please help!vgx-xl100 dvd drive ok but floppy cable naff will it plug into sata port
lardys1
hi got a xl-100 had it from new now second computer, i've broken the floppy cable from the dvd to the motherboard its got a adapter on the back of the drive can i remove this and connect a sata cable instead or do i need a power cable aswell the drive is perfect but can't get the floppy ribbon cable from anywhere. please can you help a woman in distress. thanks helen
have put some pics of my problem as i said the drive is ok but what's the adapter on back of it and can i get a different adapter so i can use spare sata port please can anyone help.
Message was edited by: lardys1
0 REPLIES 0
