Power calibration error FZ21M
AlexFoucart
hello all,
i got a problem with my vaio FZ21M...
when i burn a dvd or cd, the following error appears : Power calibration error (with any burning software) :devil:
i got the same problem a few month ago, and there were an update for the disk drive, after that, everything was all right, but now, there are no update... what can i do to solve that problem ?
regards
Alex
6 REPLIES 6
rich912
Hi Alex,
There can be many reasons for the error message you are receiving, but to narrow down the problem have a look at this LINK
It may be simply be a matter of cleaning the laser lens...
Go n-éirí an bóthar leat
AlexFoucart
Hello Rich,
thx for you message, i change my media, and it s gonna be all right...
It is verry strange I user Ritech DVD and with that, i had the problem... it s not bad media...
now i use Verbatim dvd, and it work well
Thank you verry much:smileycool:
Alex
rich912
Hi Alex,
I'm pleased to hear that you have solved your problem. For some reason Sony notebook CD/DVD drives seem to be very "media sensitive". Verbatim have always worked well for me also....
Thanks for the feedback :slight_smile:
Thalamus.
Champion
See you've not lost your touch then Rich.. :clap:
rich912
No complaints to date Thalamus :wink:
Thalamus.
Champion
Glad to hear it.. :laughing:
