Hi, my Vaio screen has rotated 90 degrees to the left and I cant work out why it happened in the first place and how to get it back to the normal position. I am currently getting a sore neck. Can anyone suggest how to fix this. Many thanks, Richard Mc
Solved! Go to Solution.
Hi Richard and welcome.
The usual way is to press 'Ctrl + Alt + One of the right or left Arrow Keys' to rotate.
I think Ctrl+Alt+Up_Arrow should return to default configuration.
If this does not work, please let us know which model Vaio you have.
Your a gent and a scholar sir, its fixed, thanks very much for your help cheers Richard
Glad to help Richard.
