Hi there everybody!
A few days ago I recovered my Vaio Vgn Fs 115m, with the dvds I 'd made when I first bought it.
The problem is that after the recovery, the 'Fn' key doesn't work, and I cannot change the volume of the music, or the brightness of the screen..
Any ideas?
Hi babyboy and welcome to the forum.
If you have a folder C:\Utils then navigate to this – otherwise download and extract the pre-installed utilities from Vaio-Link
Then install the following utilities (in this order):
1 Sony Utilities (installer folder 1)
2 Sony Shared Library (installer folder 2)
3 Vaio Event Service (installer folder 6)
Re-boot and all should be working – if not then repeat the process a couple of times.
I did it twice and it worked!
Thank you so very much!
Pleased to hear that babyboy:smileyhappy:
